vcRobotProgramManager
Container for robot programs.
Module: vcRobotics2
Parent: vcProgramManager
Referenced by: vcProgramContainer.ProgramManager, vcProgramExecutor.ProgramManager
| AutoStartProgram | vcRobotProgram | RW | Gets or sets a program that is started automatically with the simulation. |
| TargetContainer | vcMultiPositionTargetContainer | R | Gets the associated position target container. |
| loadProgramFromFile | tuple | String filePath | Loads a program from given file path and adds the prgoram to the manager.See moreThis method enforces uniqueness of the name of the loaded program by renaming when necessary. Parameters: filePath (str): Path to program file. Returns: tuple[vcProgram, str]: The loaded program and it's original name stored in the file. The name can differ if it wasn't unique and therefore was renamed. Exceptions: ValueError: when loading fails. |
| saveProgramToFile | None | String programName, String filePath | Save the given program to the given file path. The file will be overwritten, if exists.See moreParameters: programName: (str): Name of an existing program.. filePath (str): Path to program file. Returns: None Exceptions: ValueError: when saving fails. |
